Take the long way home
shift kit installation....HELP(Read 1132 times)
shift kit installation....HELP on: June 07, 2018, 02:06:01 PM
Please   help    I am trying to install the pro star and detent arm kit and I need advice...…. I can't shift now
Re: shift kit installation....HELP Reply #1 on: June 08, 2018, 01:10:53 AM
Not really familiar with that setup.
1. Did you have to split the cases to put this in?
2. Is this for a 3rd Gen Magna?
3. Did you buy the part new, come with instructions?
4. Have you called the mfg?
Re: shift kit installation....HELP Reply #2 on: June 08, 2018, 07:42:27 AM
I know someone that was on here installed this>
I believe it was LIMagna, but I could be wrong..
Do a search and see if you can figure out who, then private message them...
Re: shift kit installation....HELP Reply #3 on: June 08, 2018, 02:56:33 PM
I thought the guy in Michigan put one on his bike also, he put some type of quick shift kit or something, Chad I think it was.
Re: shift kit installation....HELP Reply #4 on: June 08, 2018, 06:43:09 PM
I'm sure a search would probably provide a result..
Re: shift kit installation....HELP Reply #5 on: June 10, 2018, 11:38:27 PM
This is a 3rd gen Magna
The instructions that came with the kit do not mention having to break the case open.  It seems like it should be pretty easy.  I know I must have read 200 post trying to figure out who and when have already did this to their bikes.  Chad from Michigan has indeed done this, but mentioned not the problem I have come across.  I'll check for LilMagna as well.   I did call the manufacturer for help and they only would repeat directly word for word what the instructions say...…."Turn the transmission WITHOUT the wheel moving OR vise versa."
unfortunately I am not sure how to turn the transmission by hand.....Suggestions Welcome.  I am very much looking forward to getting this little beauty running VERY Soon.   I pretty much maxed out the jetting and once I get this shift kit done, I plan on precision tuning the carbs due to it being pretty rich at idle and low end.    To all that are trying to help me with this THANK YOU SO MUCH.....
« Last Edit: June 10, 2018, 11:43:08 PM by KingCheetah »
Re: shift kit installation....HELP Reply #6 on: June 11, 2018, 02:11:19 AM
Send Chad a Private Message, maybe he has the same email to receive the message.
Turning the transmission without turning the rear wheel, maybe put the transmission in neutral and turning the clutch. Maybe the resistance in the transmission would move what you need to line this up.
The only way to not turn the rear wheel is having the bike in neutral other than removal of chain. Guessing they mean the countershaft sprocket does not need to be engaged so that is back to putting the bike in neutral.
Start searching youtube for videos, maybe someone will give you an idea how this is done. Then you can let us know.
Re: shift kit installation....HELP Reply #7 on: June 11, 2018, 07:44:48 AM
Put in neutral, remove he circular cap on the clutch cover plate (Right side of the bike) and then you can use a socket to rotate the motor manually.
Is there a reason you are installing this part? I know the Magna shifting is pretty terrible and I believe CHAD said it did make a significant difference, but Just want to know if you were having an issue, or just wanted the improvement.
Re: shift kit installation....HELP Reply #8 on: June 11, 2018, 12:39:37 PM
I have sent Chad an email, no response yet that I know of.  As far as the desire of wanting this part on,  I was having problems shifting from 2nd to 1st, so I ordered the kit....  Then before the kit came in I fixed the shifting problem and then $400 worth of shift kit came in and...……. well you probably know where it goes from there :-?     So now I can't get the bike to change out of whatever gear it is in( I put it in neutral before working on it, and had it all in and went to test to make sure it would go through all gears and now I'm where I am now...…)   Now I have a couple more ideas to try.  Thanks Guys   I will update as soon as I get a chance to work on it some more.      any idea on how to get it into neutral again so I can try to spin the guts from the right side?
Re: shift kit installation....HELP Reply #9 on: June 11, 2018, 04:20:11 PM
Take it back out and start over.
Re: shift kit installation....HELP Reply #10 on: June 13, 2018, 08:12:19 AM
  Nope, wasn't me but you did find the right guy.  I remember Chad being a prolific poster and generally very knowledgeable guy on the 3rd gen forums.  I haven't heard a peep from him though in many years now.  I believe he sold his bike(s) when he bought a house and that's been that.
Re: shift kit installation....HELP Reply #11 on: June 21, 2018, 01:04:04 PM
Awesome!!!   Thanks for your support     that kit is in annnnnnd  is AWESOME      its strange.....    it works so well that if your not paying attention to trying to notice/feel it.... you won't  lol
Re: shift kit installation....HELP Reply #12 on: June 21, 2018, 06:09:27 PM
Did you get a hold of CHAD? Did the Manufacturer help out? OR did you just figure it out on your own??
Re: shift kit installation....HELP Reply #13 on: June 21, 2018, 11:26:08 PM
What are the differences? And yes how did you get it to work, did you find one to help out?
