Take the long way home
Front Fork Oil - 3rd Generation Magna(Read 13750 times)
Front Fork Oil - 3rd Generation Magna on: August 20, 2010, 01:04:12 PM
How often, in mileage or years, should the front fork oil be changed on my 1999 VF750C?
How much time should the job take at a Honda dealer?
10wt or 15wt fork oil?
Thanks in advance.
Lee
Re: Front Fork Oil - 3rd Generation Magna Reply #1 on: August 20, 2010, 01:35:12 PM
There is no definite replacement interval per the service manual, which calls only for inspection every 8000 miles. If the suspension isn't exhibiting damping problems, I wouldn't screw with it.
Re: Front Fork Oil - 3rd Generation Magna Reply #2 on: August 20, 2010, 01:39:33 PM
Oh, the manual specified oil is helpfully specified as "Fork Fluid". No weight or viscosity given.
Re: Front Fork Oil - 3rd Generation Magna Reply #3 on: August 20, 2010, 02:35:31 PM
From what I understand 10wt is standard for the Magna, I went back with 15wt myself.
Re: Front Fork Oil - 3rd Generation Magna Reply #4 on: August 20, 2010, 05:09:13 PM
Thanks, guys.
I'm not having any damping problems nor fork seal leaks. So, I guess I'll wait, until I do, and then switch to progressive springs and 15 wt fork "fluid".  :wink:
Re: Front Fork Oil - 3rd Generation Magna Reply #5 on: August 20, 2010, 05:27:11 PM
Unless its leaking don't worry about it, if in the future you want to go to progressive springs then is a good time to change it however on my 2000 when I put progressive springs in the fluid looked clean just like new fluid so I left it alone.
Re: Front Fork Oil - 3rd Generation Magna Reply #6 on: August 20, 2010, 05:55:24 PM
Jerry,
That is really interesting.
I never realized fork oil lasted so long.
Lee
Re: Front Fork Oil - 3rd Generation Magna Reply #7 on: August 23, 2010, 11:20:34 AM
Your call on replacing the fork oil, but be aware that the fork oil weights are not standardized.  I.e., 10wt fork oil may not be the same viscosity between vendors.  Years ago I searched and found some viscosity indices for different fork oil vendors.  If you do change, might want to look around for something similar and current.
Re: Front Fork Oil - 3rd Generation Magna Reply #8 on: August 23, 2010, 11:29:31 AM
Lurkin,
Thanks.  :-)
I wasn't aware of that.
The more I've ridden my "new" bike, since replacement of the brake fluid, the happier I am with the overall ride.
I'm not going to mess with the springs or fork oil, unless I really need to do so.
Lee
Re: Front Fork Oil - 3rd Generation Magna Reply #9 on: August 23, 2010, 11:51:07 AM
Here's a bunch of info on fork oil specs that might be useful:
http://www.pvdwiki.com/index.php?title=Suspension_Fluid
Charlie
16 BMW R1200RT - :) :) :)
Re: Front Fork Oil - 3rd Generation Magna Reply #10 on: August 23, 2010, 01:04:07 PM
LIMagna,
I never thought fork oil would be so complicated. Of course, that's why no one ever suggested I should be an engineer.  :D
Re: Front Fork Oil - 3rd Generation Magna Reply #11 on: August 23, 2010, 01:55:20 PM
I guess it's just as complicated as engine oil.  I'm just glad it's usually not the subject of a religious crusade  ... at least not on these boards :)
Charlie
Re: Front Fork Oil - 3rd Generation Magna Reply #12 on: August 23, 2010, 03:11:16 PM
I know what you mean about those engine oil debates.  :lol:
If I started one of those threads, I'm sure my membership would be revoked.  :oops:
