What do you think about this deal?
Started by Magna86, January 03, 2009, 10:21:36 AM
Magna86
screamin meme
This is a common thing with these bikes. The cause is Honda's cheap connectors. Easy fix though, simply cut the connectors off and solder the wire back together. There is a kit on Ebay you can get to fix this problem as well. I bet your 700 has the same style connectors. Might want to check them. Bike looks good.
85 v65 Magna. 340 gears, 70a carbs, K-N filter.
Lubbock, Tx  Moot #702
Where did you get the tail/fender?  I like that, very cool.
Magna86
The tail/fender is stock. Just looks different because of the custom seat and different rear turn signals.
screamin meme
Here is a good write up on those 3 yellow wires and how to fix them.
http://v65.freeshell.org/sabmag/reg_conn.html
QuoteThe tail/fender is stock. Just looks different because of the custom seat and different rear turn signals.
Yeah, makes the whole rear look lower.  very cool.  :cool:
Quote from: Magna86 on January 04, 2009, 02:08:24 PM
the new stator/regulator melted the connector. He said not sure why and even asked the service guy about. What would cause the connector to melt where the regulator and stator connect?
The connectors do take some heat. over time they build up some resistance.. The more resistance, the more the heat, which causes more resistance, which causes more heat.. You get the idea..
Had the issue on my '94 on both connectors.. Search for "Regulator" on this site, you'll find a lot of posts from me including pictures :x
I cut out the connectors and soldered and Shrink wrapped the wires.. It has been good - So far  :-?
