Dave Dodge Drop In Cams
Started by Chokse, April 02, 2009, 05:26:56 PM
i'll swap the plugs around and see if the problem follows. great idea! i just replaced them this spring, but maybe i dropped one and cracked it, i don't remember. i do remember dropping a plug, but i thought that was one of my old test plugs, lol. maybe i have that one in there :) hey george, did they happen to say what is failing on the unit?
Must be the different power you use over there..
Quote from: Chokse on April 05, 2009, 07:40:10 PM
Yep, when the Dyna starts to act up, putting the stock CDI back in solves all the problems.  Runs like a dream with the stock CDI and runs like a dream for about two or three months with the Dyna before it craps out and dies.  I am 100 percent certain that each time it happened it was the Dyna ignition, and Dyna has confirmed this each time by testing my old unit and referring to it as a "failed" unit.
Chokse
Chad. They didn't say.  They just told me that it failed due to extreme weather changes..... all three times!  I haven't a clue what actually went wrong, but my wire connections are all good (CDI is grounded to the bracket on the left side) and I have never had a problem with the stock unit.  Same goes for my friend's bike.
