Hard Starting Problem on 84 V65
Started by jccbone62, August 11, 2009, 10:25:38 PM
jccbone62
Thanks guys for the info and words of encouragement.
I will pull the carbs tomorrow and keep you guys updated on my progress.
texas-ss-tornado
Take it from somebody who has restored a few dozen V65's over the past couple of years, have your carbs rebuilt by a PRO!  The best in the business is a guy in Canton, Tx........he's regular on the Honda V4 forum and even has his own little forum there.  I promise you, once Billy goes through your carbs, it's a slap on and go proposition, and they will look like NEW, he sonic cleans them, replaces everything that needs replaced, provides new allen head stainless screws for everything, gives you new coolant tube O-rings (best to do them when the carbs are off), and also throws in a new fuel filter!  All this for right around 200 bucks!  Turn around time is just a couple of weeks, give him a hollar, he provides great phone support too!!!
Billy Carr
20706 State Highway 19
Canton, TX 75103
903-567-1543
Current stable:
80 Honda CBX
82 Honda CB750 Nighthawk
83 Honda V65 Magna
85 Kawasaki ZL900 Eliminator
87 Kawasaki ZL1000 Eliminator
94 Yamaha V-Max
08 Suzuki B-King
QuoteHere's an update!  I replaced the civic fuel pump with another OEM pump.  I'm still having the same problem.
Here's my problem again, I started with a hard starting problem now my bike floods out and will not restart.
To restart the bike, I have to pull the spark plugs and clean and dry them out and drain all 4 carb bowels.  It will restart from this point and idle smoothly until I shut it off.  Once off, it will not restart.
My frustration level is high!
too much fuel pressure with the new fuel pump?  The float needle valves can only stop a certain amount of pressure.
