Stripped brake arm bolt
Started by ryjb, August 05, 2010, 06:16:48 PM
ryjb
So in the process of attaching my rear brake arm to the cam I realized my flange bolt had been stripped.  Besides the obvious does anyone know if a hard ware store would be a good place to look?  Or should this be something I get the correct replacement for?  Thanks
Here is a picture of the bolt I stripped.  It is circled in red.
Send me your address I have a couple of them I will send you one.
ryjb
Quote from: Jerry G Turner on August 05, 2010, 06:21:30 PM
Message sent. Thank you, Jerry!
The bolt should arrive by Tues at the latest make sure when you put the brake arm on that you have it all the way on the cam so that the bolt can slide easily thur other wise it is easy to strip the bolt ask me how i know.
ryjb
Thanks Jerry.
I am sure the way you know is most likely the same for me.
ryjb
#5
The bolt came today.  Jerry, thank you kindly once again.
