Clutch and general work
Started by Len Averyt, July 30, 2011, 07:54:51 PM
Len Averyt
QuoteI have a distributor who carries the Barnett, we have an account with them but I have never ordered from that distributor and do not know what our program is. At this point, no access.  Since this post I have contacted to see what their program is, still the answer above is accurate.
So i'm confused :-?
What does one of those kits usually run?
I'm going to do a lot of service work on the ol magna this next month
change fluids again, including..
coolant
fork oil
engine oil
oil filter
air filter
clutch service
starter service
plugwires and plugs
Moot member # 547
IIRC about 140 bucks for clutches and springs.
Len Averyt
Quote from: Chad in Michigan on July 31, 2011, 08:30:41 PM
you know what? I just remembered why I have that basket as a spare... I boogered up and broke a bolt in one or two of those holes to hold down the springs on the outside of the pressure plate... you may be able to salvage it or it may not be worth the trouble.  i know the pressure plate is still good with the bearing included and the gear and springs on the basket are good. let me know either way or if you want some and not all, let me know.
I got those parts, Thanks! I see the part with the issue. The part that has the broken bolt is no big deal. the basket and springs are the pricey part so I'm extremely glad to have them.
I'm slowly getting the parts together to do all this.
I have been side tracked with an engine rebuild with my step son. He blew up his truck engine so busy with that as well.
Moot member # 547
glad you could make use of them :)
