recommendations for spark plug wire set - 3G
Started by iceprizm, April 14, 2012, 05:26:20 PM
iceprizm
While I was pulling the boot from my spark plug the wire broke off from the boot.  :shock:
Inside the boot and the end of the wire was totally corroded, so its time for some new wires. Wondering what type or brand anyone would recommend.
1996 VF750C Magna
K&N airfilter
Vance & Hines exhaust
Progressive springs on front
Progressive 412 shocks on rear
VTX headlight mod
Shadow spirit riser mod
EBC metal sintered pads in front
EBC grooved shoes in rear
Carbs rejetted to 110, 42 and 2
tedkraus
I replaced mine with the a set from the dealer. I do not remember how much they cost, however I feel it was reasonable and worth it. Let us know if you find a good aftermarket replacement.
Current Bike:
2005 DL650 Vstrom
Past Bikes:
95 Gen III Magna VF750c
84  Gen I Magna VF700c
MagnaMikeD
Cut the bad part of the wire off and "screw" the boot back on the wire.  A little silicone on the outside of the wire will help greatly.  Hopefully you have enough length. I've done this until I ran out of length of wire needed or resistance measurement out of spec.  I then stayed with stock wires and ordered them from BikeBandit.com.  It wasn't cheep but I was assured of not changing the recommended resistance specifications.
Mike
1999 VF750C, bought new and untitled 2001.
227,401 miles, by the grace of God!!!
This is truly a magnificent machine!
2015 Kaw Concours, bought new & untitled 2017
tedkraus
Magnamike, sounds right on give that a try if no luck. hdlparts.com is another good place to look for parts.
Current Bike:
2005 DL650 Vstrom
Past Bikes:
