Main Menu
carbs
Started by BrianT, April 20, 2012, 11:52:24 AM
BrianT
hey guys, Im rebuilding a set of carbs from the wifes 85 vf500c. upon dissassembly I found a small tear in 1 of the slides. My question is will a slide form an inteceptor work from the same year? mines a 30mm. Im not sure if the interceptors used the same slide/diaphram.
Look it up on Honda parts diagram and see if the part number is the same, it still may fit but this could be your first step.
BrianT
the first 5 numbers are the same 16111-xxx-xxx, its the xxx-xxx is different. so not sure if because the first 5 are the same if the part would be the same but applicable to both where as the xxx-xxx is related to the model of the bike? or the parts are altogether different. anybody have any clue? Thanks for any feedback. :smile:
If not the same, then probably not the same part...
tedkraus
The entire serial number should match for it to be a direct replacement, exact same dimensions, design etc. Not saying that it won't fit but it is in some way different based on the info you provided.
Current Bike:
2005 DL650 Vstrom
Past Bikes:
95 Gen III Magna VF750c
84  Gen I Magna VF700c
