another exhaust question
Started by indianpride77, May 24, 2012, 02:02:10 PM
indianpride77
ok so i am looking into changing the sound of my exhaust and came across some slip ons by a company called cycle shack. The have 2 1/2" slip ons and 1 3/4 slip ons. now I'm being told that these will not work for the magna. is this true? granted i will have to check the size of my pipe but if it's a slip on won't any slip work as long as it's the correct size pipe? thanks in advance
I would think one would have to support them aft of the exhaust pipe where they slip on.  Perhaps the support brackets are in the wrong place??
indianpride77
i don't see where the brackets are even at lol
indianpride77
trying to post a picture of it but can't for some reason
I have two '96 models, both with aftermarket pipes.  Welded to the inside of the pipes is a hanger that bolts to a bracket on the frame.  I presume this is the same way the stock pipes are supported, even though I have never owned any.
indianpride77
If you look closely, there appears to be a bracket that runs between the pipes..
Are you planning on buying two sets, one for each side of the bike?
indianpride77
yeah i plan on buy a set for both sides
Gloveberg
Quote from: indianpride77 on May 24, 2012, 02:02:10 PM
Thing is with these pipes it isn't just a straight pipe.  The lower pipes do slip right on but the top pipe has a smaller 45 degree pipe attached that slips onto the header pipe.  For rear support on the stock pipes there was a welded piece that bolted to the frame.  On the aftermarket pipes I have had there were individual tabs on each pipe that lined up then bolted to the frame.
In essence you can use those slip-ons but you're going to have to do some cobbling and modifying to get them to fit and/or work.
Jimmy Glover
MOOT #9
Central Region Coordinator
1996 Magna
indianpride77
hmmm ok. i'm trying do something with out breaking the bank. i know it would probably be best just to buy the V&H bought i've already dropped almost a grand this week on it
You would really have to Cobb up the pipes on the left side as the pipes are made to be on the right... This means you would have to mount the left ones upside down as the mounting bracket will be on the wrong side...
tedkraus
Would the Cobra not be less expensive than V&H, but viable alternative?
Current Bike:
2005 DL650 Vstrom
Past Bikes:
95 Gen III Magna VF750c
84  Gen I Magna VF700c
