86 Magna 700 no power after 2.5k RPM
Started by HohltMagna700, June 14, 2012, 10:30:22 AM
The best signal that I found was at the cabins in the hill and you had to stand on a table to.
HohltMagna700
I wanted to let everyone know that the cause of the problem was in fact the coil controlling the front cylinders. As you would rev the bike, the spark would then die. just idling the spark would be weak, but anything above that. the spark would die off.
Special thank to those of you how help out and gave suggestions, and a special thanks to Phillip for sending me manual.
filstoy
#17
Glad you were able to fix it. Thanks also for posting what the problem was. It helps others who might run into a similar situation.
1986 Honda Magna VF700C
Almont,MI
Quote from: filstoy on June 18, 2012, 03:53:11 PM
Yes that does help.
So do you have a new coil and it works as it should or are you in search for one.
tedkraus
I started reading this post, thinking gotta be ignition related. Continued reading all the great suggestions, and then got to end happy you found the problem. Were you able to locate a replacement coil easily?
Current Bike:
2005 DL650 Vstrom
Past Bikes:
95 Gen III Magna VF750c
84  Gen I Magna VF700c
I am glad you know what the problem is. One more thing to be watching
HohltMagna700
Quote from: tedkraus on June 18, 2012, 09:59:09 PM
Yep, no problem, however I replaced it, and it didnt change anything. Turns out it is the CDI box actually. I checked the resistance from the pulse generators and they were within spec.
