Cam Chain Guide Broken
Started by hop along, February 22, 2014, 06:50:09 PM
It's kind of a unicycle right now.
I busted the universal joint the other weekend. It is in the front end of the swing arm assembly.
Those bolts holding the swing arm to the frame are beasts to get out. One has a special lock ring on it and I had to cut teeth on a large socket to fashion a special tool to get it off.
While it was apart, I sent the swing arm out to get powdercoated along with a bracket that holds the rear brake caliper.
