Honda About To Unveil New Family Of V4 Powered Motorcycles
Started by buster, July 29, 2013, 08:58:32 PM
Quote from: lragan on August 05, 2013, 10:43:17 AM
Quote from: L J  VFR on August 05, 2013, 09:27:52 AM
If they wanted to put a centerstand on the 3rd gen, I'm sure their engineers could have figured out how to do it.
As evidenced by the available aftermarket center stands.
Perhaps, but have you ever tried to lift an 800 lbs. motorcycle up on a center stand? I watched a guy do a Valk standard one time. It took him three attempts on a level garage floor. Of course the lighter Magnas are better candidates for this stand. I use mine occasionally on the V-65.
My goldwing has a center stand and with a little practice it can be raised fairly easy it also has a shaft drive go figure.
Magniac
We could have made the Cycle-istiC centerstand so much easier to use if Honda had put the sidestand ANYWHERE ELSE.  :mad:
Quote from: Magniac on August 08, 2013, 10:07:01 AM
So, if I take a torch and cut off my side stand, can I mount yours in a way that makes it very easy to use?
