Magnetic Solenoid Relay
Started by ripster31, November 30, 2015, 08:59:50 PM
ripster31
Just wanted to drop this in, just in case someone runs into the same problem.  I have a 1996 VF750C.  While riding, the bike would just lose all power and die.  After doing this for a while, then it got to where when you tried to crack it, it would pop and lose all power.  Finally narrowed it down to the solenoid relay.  It was a give away, due every time I would try and start the bike you can hear and feel that relay pop.  Replace it, and now she runs better than when I got her.  I don't even have the flickering of the headlight like I used to.   Just FYI in case someone runs into the same problem.
There is a couple of relays on the bike.. Where is this one located?
Or do you have a picture?
Pondering how that would cause the problem you indicated.
ripster31
Its the relay that the main fuse is located on.  When I took the seat off and tried to crank it, you could hear and feel it make a pop noise.  I would have to wiggle the wiring harness that plugs into it to get the power to come back on.  I inspected the wiring harness, and could not find any short.  I decided to change it out, and now the problem is gone.
http://www.amazon.com/Motorcycle-1994-2003-1990-1997-Interceptor-1998-2009/dp/B008X59GO0/ref=sr_1_fkmr0_1?ie=UTF8&qid=1449196799&sr=8-1-fkmr0&keywords=1996+vf750c+magnetic+solenoid+relay
$10 fix.. Pretty sweet.. It was all the BS you had to go thru to figure out it was the $10 part that was tough!
ripster31
yeah it was lol.  She is purring like a kitten now.
