Dyno Jet Tuning Question - Update
Started by 2fs2ns, October 17, 2006, 11:41:52 PM
2fs2ns
Turned screws out just over 3 turns.  Barely bogs at throttle up, midrange is good, and popping is better, but still present.  Starts popping under 4k rpms, but isn't as frequent.
Might try to turn out a little.  But I need to get a new air filter, be it stock or k&n before I really try to dial it in.
Completely getting rid of the decel pop may be a futile persuit.  My '99 is completely stock and pops on decel some.  It's just hard to hear with the stock pipes.
2fs2ns
That's cool then, aside from the popping it's running pretty smooth then.
Think a K&N will require needle adjustments?  Just stick with stock?
Ride it a few weeks, pull a plug and read it, white and chaulky too lean, dark brownish/black and wet too rich.  Want it a nice golden brown.
2fs2ns
I pulled my plugs last night, probably over 1k miles on them.  Looks like it's running a little lean as the plugs are a bit chalky.
I've also added a k&n since this original topic.
Would going to 108 jets be the best way to get more fuel in there?
105's should be adequate, moving the clip on the needle will probably cure the issue.
archiefl98
Figured I'd pop my head in on this one.  I'm the guy who did the writeup on shotsnapped.com about installing the DynoJet kit.  I put the 108 jets in and had a rough time of adjusting the pilot screws myself.  When I rejetted I had put a K&N air filter in, hacked the crap out of my mufflers (removed the baffle and the backplate) and had a bit of popping.
I found out a little late that when I finally got rid of the popping I had turned the screws WAY too far out on the #1 and #3 carbs and ended up fouling two plugs.
After that I changed the plugs and started turning the screws from closed again.  I set them about 3 full turns out and still had minor popping.
Then I installed my Cobra exhaust.  Initially it was still a little bit cold outside here in NJ and I still had minor popping on decel.  Since it's warmed up I rarely have popping at all.  When I do it sounds like it's always on the same single cylinder, so I'm going to adjust the screws on the right side out another 1/4 turn, one cyl at a time until it's gone completely.
The DynoJet kit says to use the 108's with a modified or aftermarket exhaust.  I tend to think that they're not so much for "modified" as they are for "aftermarket" because things have been a lot smoother since the Cobra pipes.
My $0.02
-Arch
Arch, stock muffler mod is usually just the endplate and resonator "adjustments" LoL.  The rest of the pipe still has restrictions.
They simply dont flow enough for the aftermarket jets I dont think, especially without a K&N.
I have been playing with pilot adjustments with the Dyna-jet kits and found that 3 1/8- 3 1/4 turns out from a light seat are just about right for your scenario..
archiefl98
Thanks for the info, Greg.  I believe I'm at about 3 turns now, so I'll tweak the next 1/8-1/4 turn this weekend.
-Arch
