Polishing Wheels
Started by tmds3, April 03, 2009, 09:38:46 AM
Very tempting -- but I would have to remove the clear coat that protects the wheel to do this, and then would need to polish it regularly.
I might, though.  It looks really nice.
My rear wheel is pretty well hidden, so I would only do this for the front.
Has anyone polished the front wheel on a Magna?  How well does the aluminum wheel hold up once the clear coat is gone?  Is there a way to protect it again (new clear coat)?
After you remove the clear coat and give it a good polish, can you not spray it with a clear coat again?
No clear coat on the rims, time to polish, get to work.  :-P :-P
I ask because I stripped the clear coat off some parts to polish them or pain them.  I really don't want to have to keep re-polishing.  I was hoping after I polished I could just spray them with clear coat again.  If not, then they are going to be black or silver paint.
I'm with you, DG.  Don't understand Terry's post at all.
Has anyone successfully re-coated their front wheel?
Yes you can respray with clear coat but you will have to remove all the polish residue to get a good clean surface for the paint to adhere on, use a good paint also. If the area is around where fuel might be a factor you have to use a paint resistant to gas.
Lawrence, on the 3 gen Magna's the rims are not clear coated, I polished mine a bit a few weeks ago.
tmds3
How long do you think it would take to do this with a drill and the polishing wheel?
You can do it pretty fast with a drill and wheel, before I go on I better look at your video.
Get some sewn polishing wheels, polishing sticks, finish with Mag. Polish, it will look pretty good. The problem is getting in all the tight places your fancy drill won't fit. If you need more detail on how or what supplies to get, post up.
SmokedU also has a write-up on a different way using diesel, both work.
Here is a thread where I polished my GT380 motor.
http://www.magnaownersoftexas.com/forums/index.php?topic=1908.msg14518#msg14518
tmds3
Quote from: TLRam1 on April 03, 2009, 05:30:47 PM
What about Dremel for the tight spots?
Quote from: tmds3 on April 03, 2009, 05:41:17 PM
If you have access, Dremel works well!
Quote from: TLRam1 on April 03, 2009, 03:55:53 PM
Thanks, Terry.  I don't know where I got the idea that it was coated.  I intend to polish away.  I really like the polished look.
drkngas
I use the Mothers Power Ball Mini.  Works great on rims.  Sometimes I use the Mothers polish with it but usually the stuff I buy at the Int'l Bike SHow every year that they show off by polishing the bottoms of coke cans and old coins.
http://www.autogeek.net/powerballmini.html
you can get the power ball at all auto parts stores.
David Morris-Katy, TX
MOOT#362
Now:05 Royal Star Tour Deluxe
kwale86
I polished my rear wheel when I changed the tire last year.  I tried using the Mothers Power ball or whatever it was called.  It did not work well at all.  I ended up using Mothers polish (which has always worked well for me.  I had a lot of corrosion on my wheels that would not come off with mothers and a rag.  So I went to my wife's kitchen and got a couple scotchbrite (green and yellow sponge scrubber pads)  I used them and lots of elbow grease and it came out looking pretty good.  I used soft rags after I got all the corrosion off.
Kale Tifft
Moot # 475
99 Magna
