fuel tank hose
Started by cluke3, January 24, 2010, 12:05:37 PM
cluke3
any body happen to have the main fuel tank hose for the 84 v30 magna
EnglishMagna
Hi I'm not sure if parts are more readily available over there in the US (I'm in the UK) but when my pipe failed I struggled to find a replacement. At first I just used a normal straight house but it soon burst due to the sharpness of the bend, so I made a replacement out of copper plumbing pipe. I assume you have similar stuff over there but I took 2 copper integral solder joints (the type that have solder already in them and that you just heat with a blow lamp) each with a 90 degree bend and then joined them with as short a piece of copper tubing as possible. I then simply added a piece of rubber tubing on to each end again as short as possible and then used this set up to link the 2 petrol tanks. I'll admit its a bit of a squeeze to get it to fit in place under the rear tank mounting but provided you keep all parts as short as possible there is room just about. I carried this out on my own V30 that I use practically every day a couple of years ago and I've had no problem with leaks since.
Nice innovative fix.  Thanks for sharing with us.
cluke3
thanks for that info i also found that the hose can still
be bought from honda
