engine died
Started by punchy, July 15, 2010, 06:45:40 AM
LIMagna
From what I remember, I used a brown & white wire that loops on the back side of one of the connectors inside the headlight housing.  It's hot only with the ignition on and doesn't have any issues with high/low beam switch position.  I cut it, attached some crimp connectors and spliced in a fuse holder which now feeds my battery gauge.  If I end up with a short with the wire running out of the housing to the gauge, it will blow the 1 amp fuse I installed before blowing the main one back under the seat and I should still have my headlight working.
Charlie
16 BMW R1200RT - :) :) :)
