I have searched to no avail...horns and relays
Started by sdswingr, August 02, 2011, 05:08:04 PM
sdswingr
So I am attempting to install a set of dual FIAMM freeway blaster horns...I had them on my previous bike, and they did their job well.
I have searched here, have searched google...tried this...
Roughly copied http://www.easternbeaver.com/Main/Products/Horn_Kits/body_horn_kits.html#dualhornswiring harness..and nothing..I ended up blowing my 15a fuse on the bike..
any help here would be appreciated...
I can get one to work with the stock wires...but it isn't as loud as it should be...which is why I am trying to install with a relay...
1998 Magna 750
1995 Suzuki Intruder 800
sdswingr
Ok...a little more digging..found this...http://www.ridethatbike.com/NOMAD%20orginal/Horn%20Freeway%20Dia.JPG
Problem solved..nice 132db of dual toned truck horn pleasure.. :-D
1998 Magna 750
Did not have time to look at your link but you must use a relay pulling from your battery to blow the horn.
I like air horn people now you are there
