Quick question about fork springs...
Started by TAC, May 20, 2012, 03:54:16 PM
TAC
Hi
does anyone know if the fork springs from a 750 VFR ('88/'89) would fit a V30 magna ('84) ?
Have been offered a (very) cheap set of progrssives, but dont know if they use the same spring size?
thanks in advance,
tac
Look on a site like BikeBandit.com and see if they are the same part number...
TAC
Quote from: hootmon on May 20, 2012, 05:08:13 PM
they're a different part number on BikeBandit's own numbers...   :-(     is there a site that uses Honda's OEM part numbers?
Imabass
if the diameter is the same then they should work.  You will need to make a custom spacer.  I use thick wall PVC and a washer on each side.  The spacers need to be exactly the same length
