Tip - Removing the engine using engine hoist. Must see video
Started by Imabass, June 05, 2012, 11:45:53 PM
Imabass
I got the idea from someone else. Several years ago I saw where someone made a C shaped lifting sling.  It was made out of a single piece of 1/2 plate.  I don't have any scrap plate nor am I going to buy a piece large enough to build one.  I got the idea to make one from 3 pieces of scrap tubing and my load leveled that I use for removing car engines. I welded the three pieces but if you don't have a welder you could make a bolt together unit.
I recently swapped engines on my magna and I am certain that this would have made that job easier.
video is here ==>  http://youtu.be/AmgxXqckU7k
tedkraus
Great idea. My web is running slow so I couldnt watch the vid so pardon if you explained this, but what was wrong with the old engine why swap?  Thanks
Current Bike:
2005 DL650 Vstrom
Past Bikes:
95 Gen III Magna VF750c
84  Gen I Magna VF700c
Imabass
the frame was damaged from a wreck that previous owner had and insurance totaled it.  So it was more of a frame swap.
hop along
I have another preferred method similar to this... I work in the entertainment industry and we often have big heavy stuff that needs to be moved, usually way overhead.  Chain hoists are ubiquitous... and great for this kind of application.  Nothing like a 1Ton hoist to use as overkill!
It's also nice having most of the tools I need available to borrow from work ;-)
thanks for sharing the video
Hop Along
Hop Along
No longer in Norman, OK
2003 Magna
Find a friend and simply slide it out the side...  Worked for me on the Project 96 Magna.
guywheatley
Quote from: Greg Cothern on June 06, 2012, 05:50:06 PM
Yeah, but you've got friends.   :-P
Guy
Quote from: guywheatley on June 07, 2012, 08:32:57 AM
Burly ones at that...
Sounds like you need to hold a wrench session!  Then you engine hoists will show up!
grandpaul
With a Magna, you want a bike lift to do the job. Slide it under, raise it to the required level to just "lighten" it in the frame, remove all the fastening through-bolts and the left side frame tube, and lower away.
Piece of cake.
Bike lifts are like, what, $50 now?
-GrandPaul
Proprietor of Born Again Bikes Refurbs & restorations
Author, "Old Bikes"
