carb flooding on 95 magna
Started by two-stroke-brit, May 12, 2016, 08:08:26 AM
two-stroke-brit
Hi all, my buddy has this 95 magna that sat for 3 ish years .
asked me to get it running.
petcock is stuck and the carbs all flood through.
so carbs off , new float needles and gaskets.
checked the floats ,all good.
but on re install one carb keeps flooding .
i think the needle seat is damaged.
any one got a fix for this?
thanks mark
phoo1234567
Hi two-stroke-brit,
I'm pretty sure the seats in the gen 3 carbs are pressed in.  If you've already put new needles in it and one still sticks, I've read that some1000 grit and a Q-tip or an old needle can bring the seat back to life but be careful when doing this.  Don't over do it.
Good luck,
Mark
"Like you, I have no idea what you are doing, but I'm pretty sure it is wrong."
Quote from: phoo1234567 on June 11, 2016, 12:39:54 PM
As far as I can tell they are pressed in too. Don't see a way to remove them and I've never seen a kit for replacing them either.
