slow idle drop
Started by silveradocowboy, September 24, 2006, 01:17:46 PM
Been working on Deb's V45 Magna and it slowly drops the idle speed. It is worse when you are riding it, the idle takes 2-3 seconds to drop down so the gears don't grind when shifting. I cleaned the carbs last night (finally got to use my ultrasonic cleaner!) so I'm pretty sure the carbs are not dirty or clogged. Anybody have any idea what would cause this?
Jeff just out of curosity does the throttle return slowly or does it snap back normally?
It snaps back very well. I also checked the cables to make sure there was a little slack. I'm replaceing seals and gaskets between the air filter and air box from Greg's suggestion. Curtis also suggested that I check the diaphrams.
kdf9511
I was just talking about this same situation on my bike this weekend with some guys.  Mine mailny does this when it gets hot.  I was told to check for an air leek in the boots.  You might want to look there too.
