3rd Gen Magna Clutch "Lifter Rod" Seal Leaking
Started by MagnaMikeD, December 06, 2014, 12:42:08 PM
MagnaMikeD
OK, I've used the search function, but cannot come up with anything on the 3rd Gen Magna clutch lifter rod seal.  My seal is leaking enough to accumulate on the cover.  Its not catastrophic yet but doing my research. Has anyone replaced one before? Can I just pull out the old one and tap in the new one? Or, does it require cracking the case if it is installed from the inside?  Check out the pics for location. Its behind the drive sprocket cover on the left side of bike.
195,000 miles and still rolling!!
Mike
1999 VF750C, bought new and untitled 2001.
227,401 miles, by the grace of God!!!
This is truly a magnificent machine!
2015 Kaw Concours, bought new & untitled 2017
Mike many of those are put on from the outside and you can just find a way to pull that one out and install a new one, pretty common on bikes.
Some kind of hook might work, if metal on the outside, a sheet metal screw might work, think along those lines. If put on from the inside the case or cover will have to come off/apart.
Is there a way you can just re-direct the leak a little so it auto oils the chain for you?? LOL..
Only 195K and you have an oil leak.. I wish Honda made a better bike!!! LOL
Forget what I said I like the auto oiler better.
SkyRide
I had the same leak on my 1st gen.  Yours looks different but the heat shrink fix might work better for you than it did for me. Search for Oil leak at clutch slave cylinder
My seal installs from the inside, but I found instructions for grinding off the lip and installing a new seal from the outside.  It is scary, but worked great.
Rick Frankenberger
83 VF750C
San Antonio
Mike,
Have you pulled out your Lifter rod yet? - You need to make sure the seal surface on the rod is still good as well..
Let us know how it turns out..
MagnaMikeD
Quote from: hootmon on December 06, 2014, 09:02:56 PM
Yes, Hootmon, I have been very fortunate with this bike and the service it has given me.
Mike
Mike
MagnaMikeD
Quote from: hootmon on December 07, 2014, 08:32:32 AM
Mike,
The surface of the rod is pretty good.  I hate to polish it and cause it to leak worse.
Mike
Mike
MagnaMikeD
Quote from: SkyRide on December 06, 2014, 11:08:27 PM
Rick Frankenberger
Rick,
I like the idea of heatshrink.  I've been racking my brain for a way to build up the surface of the rod.  I guess worst case is pulling the seal, and if the engine case does have a lip, grind it off and install the new seal.  Then maybe some good old JB Weld?!
Mike
Mike
SkyRide
Mike,
The heat shrink is inexpensive; I would order two so you can put on a second coat in case one is not thick enough.
Pull the push rod our and turn it around.  Mine was symmetrical so I got a new surface against the seal.
If it comes to replacing the seal, I have some good pics and notes of how I did it
Rick.
83 VF750C
San Antonio
Quote from: MagnaMikeD on December 07, 2014, 03:56:30 PM
Mike
Mike - instead of JB Weld, I'd go with Loctite Sleeve Retainer - Not quite what it's made for, but should work in this application
Or we use this for our seals in the marine Industry on Gear Cases..
PRO Gasket Sealer
I can't offer anything more then what everyone else has, but, 195,000 miles!!!  Now you are just showing off!   :D :D :D
MagnaMikeD
Quote from: hootmon on December 07, 2014, 06:01:26 PM
Mike
PRO Gasket Sealer
Great idea.
Mike
MagnaMikeD
Quote from: SkyRide on December 07, 2014, 04:55:20 PM
Mike,
Rick.
I'll try turning it around. Thanks Rick.
Mike
MagnaMikeD
Quote from: Lurkin on December 09, 2014, 09:16:27 AM
Hi Lurking,
Its taken 13 years of commuting to get here.  And, man, what a reliable machine the Magna is. Sometimes I think the bike is over-engineered. Very good for us users.
Mike
Mike
