Progressive Springs & Front Fork Seals for 3rd Gen
Started by lragan, January 26, 2009, 10:42:32 AM
IMO it is important to use as close to the exact amount as possible.  I measured mine out for each side.
If you are only changing the oil and not replacing the seals, be sure you compress/decompress the forks several times to be sure you get all of the old oil out.
#46
Deleted.
#47
I put in the progressive fork springs last night.  I cut my spacers to 5-7/16 .  Was a little rough putting on the fork caps but I managed.  I put in the pro honda 10 wt fork oil.  I also put loctite on the drain screws.  After I was done, I noticed that the service manual had a replace sign beside the washers. I instead had already reused the original washers and completed the project. The forks are not leaking.  Am I the only one that did not replace the washers on the drain bolts?  Opinions?
I think you will like you cut the spacers longer. I doubt if I replaced my washers either, can't remember, are they crush washers?
Quote from: TLRam1 on February 12, 2009, 01:27:35 PM
Yes they are Terry!   That's what made me cringe when I read the service manual.
Hhhmmmm -- I am beginning to see the value of being lazy and not changing the oil...
Quote from: lragan on February 12, 2009, 05:25:31 PM
ha ha hah .........I had a 12 hp Murray riding mower for 17 years and never changed the oil.  I always figured the mower would fall apart before the Briggs commercial engine.  I finally gave it to my next door neighbor and he's still using it.  It doesn't smoke except when you first start it.  Amazing.  :?
I have installed several pairs of the springs and not replaced the washer on the drain plug and have had no ill effects.
After riding, still no leak. Thanks for the responses. :-D
tmds3
Well finally got a weekend and put the new springs in and took for a test ride. MAN what a difference these things make. Cant wait to get the S/S brake line and put it on.Gonna do that when I put the risers and new bars on.(next set of upgrades)
Pics Below
