1995 Honda Magna Blowing gas from exaust after instaling jets kit.Please help.
Started by ross, July 10, 2011, 01:48:48 PM
ross
Hi. I just both a 1995 Magna VF750 and removed the crbs  to clean them and install jet kit that I got on ebay.The kit included a 105's -42's and shims.The bike was with cobra exaust and knm air filter.After instalation it start blowing gas from the exaust and no start.It has a spark and the plugs are new.I did the instalation by the instructions and turned the AFM scrues 2 7/8 turns from closed position.Please if somebody know somethink -help.
OK lets start with the easy.  I DO NOT MEAN this as a negative, as I have done it  myself!  Did you put the run button to on?????
ross
Yes I put the run boton on.The bike is starting for a 7-10 sec.and after this it start blowing gas fron exaust.
drkngas
Is this the Dynojet or Cobra Stage 1 kit you bought on ebay? You might have the needles off by groove or more.  I was off one groove and that's how I came up with the name drkngas
David Morris-Katy, TX
MOOT#362
Now:05 Royal Star Tour Deluxe
ross
ross
I dont even know what is this e-clip.I don't know if I instaled the shims in the right place.The jets are easy to install once you take out the carb's but instructions for the shims are not to helpfull.
Well the e-clip should be in the 3rd notch down and you are saying you are getting raw fuel out the pipes?
tedkraus
are the carbs flooding? or just moving too much fuel? if they are flooding could be a float or some valve is stuck, if they are moving to much fuel as other said check e-clip position.
Current Bike:
2005 DL650 Vstrom
Past Bikes:
95 Gen III Magna VF750c
84  Gen I Magna VF700c
drkngas
Quote from: ross on July 10, 2011, 03:41:27 PM
I install a dinojet kit
Quote from: ross on July 10, 2011, 04:33:59 PM
Are you sure you installed a dynojet kit? Do you have alot of spare parts?
MOOT#362
Quote from: tedkraus on July 10, 2011, 05:31:09 PM
I'm with Ted here.. I think you have a stuck float.. I could be wrong, but that's where I would suspect..
Be careful.. IF it is a stuck float, then you have put a lot of gas into a cylinder.. That fuel will drain down past the rings and into your oil.. IF this is what has happened, once fixed, you need to replace your oil and filter again..
ross
Yes I install the dinojet kit .They ofer it in 2 options :Main jets only 105's or Main jets 105's Idle jets 42's ,shims and D tool.I install the full kit.Before was blowing gas from front right cylinder.Now is Blowing gas from left 2 cylinders.
i think there is gas in your oil.. i would not attempt to start it at this point. check your oil, see if it is full of gas or smells like gas very strongly. drain oil ASAP.
drkngas
Not to sound insulting.  When I installed mine I remember e-clips, needles, jets but not shims.  I thought Dyno and Cobra were the same.  If it was running fine before the Dyno kit, I'd remove the carbs and retrace your steps.
MOOT#362
Quote from: drkngas on July 10, 2011, 09:22:01 PM
good point - the stock setup has shims. if you are running an adjustable needle, take off any and all shims, they are not needed and will make it waayyy too rich.
